Attempts issue - Urgent
Sarah Isaacs
Hi I have an error when I go to create a new issue.
Something went wrong
All I did was update an automation this morning and add another column?
Please help as I need to do a lot of testing work today on our new board and have this error so I cannot create an epic to test.
I have turned off the last automation I altered and deleted the column. I have refreshed the board several times and shut board all other boards I was using.
Please can someone help as I have so much work to do and I'm totally stuck.
thanks so much
2 accepted
John Funk
Hi Sarah,
Try clearing your cache or using Incognito in another browser session to see if it still happens.
Ste Wright
Hi @Sarah Isaacs
Does this happen for all users, or just yourself? Have you tried logging in and out to refresh your session?
I'd raise with support though now, just so it's in their queue - contact them here: https://support.atlassian.com/contact/#/
Ste
Sarah Isaacs
Thank you problem solved you guys are the best thanks
John Funk
Great to hear! What was the actual solution?
Like • Ste Wright likes this
Sarah Isaacs
@John Funk  Not the best Solution, but I just remade the board and copied everything over.
