Is there any documentation or tutorial on how to integrate the Atlassian MCP with a GitHub repository for use with the Copilot Coding Agent (not to be confused with the Copilot Agent mode inside IDEs)?
We’d like the Copilot agent to have context from JIRA issues so it can work on them and correctly link the changes back to their respective tickets.
So far, I found two pieces of information that seem to contradict the possibility of such integration:
https://docs.github.com/en/copilot/how-tos/use-copilot-agents/coding-agent/extend-coding-agent-with-mcp
> Copilot coding agent does not currently support remote MCP servers that leverage OAuth for authentication and authorization.
https://support.atlassian.com/atlassian-rovo-mcp-server/docs/authentication-and-authorization/
> The Atlassian Rovo MCP Server uses OAuth 2.1 authentication for secure, permission-based access to your Atlassian Cloud data.
Could you please clarify this topic?
Is my understanding correct that this integration is currently not possible?
If not entirely, could you suggest any possible workarounds?
Any example MCP JSON configurations to achieve this functionality (ideally with read-only access to JIRA) would also be highly appreciated.
Hey @Peter Hostačný ,
There's an MCP dedicated group Atlassian Rovo MCP Server, where you might get better support regarding this.
Meanwhile, I'll ask the moderator team if they can move this post/question to the mentioned group.
Tobi
