Authentication -> JIRA(options=jiraOptions, basic_auth.. Not working
Cláudia Silva
March 5, 2025 edited
So far I have used authentication using the JIRA class instance and everything has worked so far.
jiraOptions = {'server': "https://example.atlassian.net"}
jira = JIRA(options=jiraOptions, basic_auth=(EMAIL, API_TOKEN))
Now when running it gives the error raise JIRAError( jira.exceptions.JIRAError: JiraError HTTP 403 url: https://example.atlassian.net/rest/api/2/serverInfo text: (...)
Bad request. We can't connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner.
If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation.
I've tried replacing jiraOptions with the information directly, but nothing works.
Two notes: I am using version jira=3.8.0 and If I execute a function through a direct URL and with the Email and Token authentication accesses, it works. Functions with the JIRA class instance do not.
Has the authentication method changed?
Can anyone help me?
Mirek
Hi @Cláudia Silva
Just wanted to check if you were able to bypass this problem. I suspect that those problems might be related to this incident that happened and resulted that many users had issues with authentication resulting in 403..
https://jira-software.status.atlassian.com/incidents/0cjw1ncyggd8
