Auto-Add Watchers When Mentioned in the comment problem
Omri Zeman January 6, 2025
Hey I make automation that everytime when you mention some user in the comment he become the watcher also.
But the problem that is worked just when you tag only one user, if I tag multiple users its don't work.
can someone have answer what I need to change in the automation to fix it?
Im attach picture of the automation.
thanks.
(this is the smart value code:
{{issue.comments.last.body.split(" ").match("(accountid:.*)]").remove("accountid:")}}
2 accepted
January 6, 2025
Hi @Omri Zeman
To add multiple users mentioned as watchers the rule will need to iterate over them with advanced branching.
Please see this earlier post I made on how to do this: https://community.atlassian.com/t5/Automation-questions/Re-Re-Finding-Mentioning-a-User-in-Comment-and-Cust/qaq-p/2368567/comment-id/6895#M6895
Is this the correct smart value code for now?
January 7, 2025
That will work, although there are various ways to perform the matching / parsing.
The key for your question about multiple watchers is the need for the branching.  Please see that linked answer for more details.
Like Omri Zeman likes this
Omri Zeman January 7, 2025
Thank you :)
Like Bill Sheboy likes this
Brandon Moberg
@Bill Sheboy One thing I've noticed is it's possible for users to be tagged in a comment without spacing between the tags, so the above smart value with split would only work for
[~accountid:XXXXX] [~accountid:XXXYYYYY]
and not for
[~accountid:XXXXX][~accountid:XXXYYYYY]
Have you run into that and found a more preferred matching/parsing approach on your end?
February 14, 2025
Hi @Brandon Moberg
The split() helps to solve some formatting problems, but isn't strictly necessary.  It can help with newlines and markup in the field.
Two alternatives are to remove the split() and try:
  • add the text function before the match() to strip some formatting
  • explicitly replace newlines with replace("\n", " ") before the match()
Like Brandon Moberg likes this
Brandon Moberg
Thank you, Bill! I ended up going with this solution, which seems to be working for all my different tests. It will extract any account IDs mentioned in the comment regardless of how they're spaced or not:
{{issue.comments.last.body.match("\[~accountid:(.+?)\]")}}
Fingers crossed I don't run into any edge cases!
Duc Thang TRAN
January 6, 2025
Hello @Omri Zeman
Seem the smart value of your automation is correct. -> KB link https://community.atlassian.com/t5/Jira-articles/Auto-Add-Watchers-When-User-Is-Mentioned/ba-p/2556829
Can you share the log automation ?
Best,
Hey did you mean to that?
Duc Thang TRAN
January 6, 2025
Hello @Omri Zeman
Based on your screen, the smart value doesn’t seem to match the condition.
That’s why the automation isn’t adding the ID of the tagged person as a watcher.
Can you check if some logs have successfully recorded actions?
If all logs didn’t meet the condition, maybe you can try adding a "log action" with the same smart value just before the condition to verify what the value is.
Vitalii_Bobak_SaaSJet
Hi @Omri Zeman,
Alternatively, if you’re regularly working with mentions and need a more streamlined way to manage them, have you checked out the Mentions Dashboard for Jira? It’s a gadget that helps you track and manage all mentions in Jira comments. This could complement your automation by giving you a centralized view of all mentions across tasks, ensuring nothing gets overlooked.
With the Mentions Dashboard, you'll be able to:
  • Easily see all tasks where you or your team are mentioned.
  • Identify mentions that still need attention or action.
  • Ensure smooth collaboration by not missing any critical mentions.
Add-on newly released and developed by my team.
Best of luck with your automation!
