Auto Link multiple tickets while creating ticket with automation.
Rajesh Konda
Hi Team,
Have a requirement to create a ticket based on schedule interval and they want to link 2 tickets to that auto create ticket. Have tried adding one on the linked issue and the other on the More action. The one on the linked issue worked and displayed on the ticket, however the link added Json not worked. So i have added both links in json code, this time it wasn't linked any one. Can any one suggest me please. Sharing the code used on the automation.
Code :
"fields": {
"issueLinks": [
"add": {
"type": {
"name": "relates to"
"outwardIssue": {
"key": "{{CMB-2457}}"
"add": {
"type": {
"outwardIssue": {
"key": "{{CMB-4100}}"
Sebastian Krzewiński
Hi @Rajesh Konda
As I understand CMB-4100 and CMB-2457 are tickets in your Jira. In that case you can't use {{ }} tags with issue keys. {{ }} are reserved for smart values.
IMO is shoulbe be "key":"CMB-4100"
More info: https://confluence.atlassian.com/jirakb/how-to-use-rest-api-to-add-issue-links-in-jira-issues-939932271.html
Seba
Rajesh Konda
Hi @Sebastian KrzewiÅ„ski  Thanks for the link, have tried with it. Getting an error as
 (Too many operations (2) provided for field 'issuelinks'. We support at most 1 operation for this field. (issuelinks)). May be automation will not allow to multiple issue linking?
Technically in Jira Cloud UI you are also linking issue by issue (not in a bulk) so I can believe that Jira automation is blocking that.
You can split this action into 2 seperate.
Like • Rajesh Konda likes this
April 9, 2024
Hi @Rajesh Konda
Adding to Sebastian's answer...
If you read the article provided, there is an open defect that only one link may be added when an issue is created or edited: https://jira.atlassian.com/browse/JRACLOUD-81845
Additionally, there are potential racetrack error problems trying to add / change links too quickly in rules.  I recommend creating your issue, adding a Re-fetch Issue action, and then trying to add the link with a separate action.
Like • Sebastian Krzewiński likes this
Rajesh Konda
Thanks @Bill Sheboy , Re-fetch issue action worked. Thanks always.
Like • Bill Sheboy likes this
FREE
