Auto-assign custom field value when create sub-tasks
Tom Hughes-Croucher May 14, 2013
We filter our Kanban boards based on a custom team field. Is there a way to make all sub-tasks that are created automatically inherit the team of the story they belong to so filtering is easy?
Udo Brand
May 14, 2013
You could use the postfunction Set field value from parent (JIRA Misc Workflow Extension Plugin which is available for Ondemand) in you Create transition.
Jos Braaksma May 15, 2013
have a look at Slingshot Updatefields (I'm the author), its a configurable listener for synchronisation between related issues. cheers
David Chan
May 14, 2013
This is not possible with the default bundled JIRA, but there are plugins that can do this, for example:
This has a "Copy list of custom fields from parent" option
Help us plant more trees
