Auto-assign user if work item is in the nearest unreleased fix version
Silvia Saric
Is it possible to create an automation that does the following:
When work item is transitioned from "PR created" to "Testing on DEV" - assign the QA if the work item is in the next unreleased fixed version ...
Basically, what I want to achieve is that if a work item is in the nearest upcoming release, then it gets auto-assigned to the QA so he immediately knows his testing priorities.
Thanks in advance,
Silvia
John Funk
Hi Silvia,
Try this:
Silvia Saric
@Mehdi Bouazza Is it even possible to have "next unreleased version" as a Value in the condition? Does not seem like it to me.
John Funk
No it is not possible. That is why I was asking if it had been tested.
Mehdi Bouazza October 20, 2025
Hello @Silvia Saric
1. The Trigger (When)
You need to set the automation to start when the status changes:
  • Trigger: Work Item Transitioned
  • From Status: "PR created"
  • To Status: "Testing on DEV"
2. The Condition (If)
  • Condition: Work item fields condition
      Field : Fix version
    • Condition:  Equals
    • Value: next unreleased version
3. The Action (Then)
  • Action: Assign the work item
  • To: The designated QA User/Role
John Funk
Hi Mehdi - Have you tested that rule?
