I'm trying making automation (by Jira Automation App) that will set a value on number field based on:
Creation Date [minus] Closing Date
Yet I don't really know how should I make it.
So far my idea was to make a smart value as shown in attached file, but ofc didn't work :(
What shall I do to make it work?
{{issue.created
Hi @Sagi Gueta
You have to use diff function for that.
{{issue.closed.diff(issue.created).days}}
You can change the unit as you want, please check the documentation.
Documentation :
https://confluence.atlassian.com/automation/jira-smart-values-date-and-time-993924864.html
Regards
Thanks for the tip, though I guess I did something wrong..
By the method you suggested to use, it should fill the field with number right? Unfortunately it didn't work when I did it.
I think what you want is
{{issue.resolved.diff(issue.created).days}}
closed will only work if you created the field. resolved is a system field that store the resolution date.
Regards
