Auto populated parent issue id to description field of Sub:task
siva
Autopopulate the parent issue ID to  Sub:Task Description field during the creation of the Sub:Task  issue type and the auto poulated description should be "See parent ticket xxx-1234" and parent id should have a hyperlink. Please help me how to achieve this.
At below i'm attaching the screen shot where i entered manually.
Note- we are using scriptrunner in our organization.
Siva.
Vikrant Yadav
Hi @siva  Apply Custom script post-function on subtask workflow to display parent issue key in Subtask description field.
import com.atlassian.jira.issue.UpdateIssueRequest
//import com.atlassian.jira.config.properties.APKeys
//def baseUrl = ComponentAccessor.getApplicationProperties().getString(APKeys.JIRA_BASEURL)
issue.setDescription("${issue?.getParentObject()?.getKey()} is the parent issue key")
 Hope it works for you!
V.Y
siva
@Vikrant Yadav
Thanks for the reply and the above mension script works thank you very much for your help.
Siva
Like Vikrant Yadav likes this
Vikrant Yadav
@siva Cool! Glad to hear it works for you!
Thank You
V.Y
Fabian Lim
Hi @siva
You will need to use a post function that overwrites the description with the parent's key.
Here are the details: https://library.adaptavist.com/entity/copy-field-value-from-parent-issue-to-sub-task-upon-creation
Regards
siva
Hi @Fabian Lim
Thanks for the early reply gone throw the script but actually i'm new to the scriptrunner so, i'm bit confused can you please paste the modified script code that shows  parent issue key ID  in description field in Sub:Task
Example : See parent ticket Siva-1234     here Siva-1234 is parent issue key ID
Thanks for the help truely appreciated
Siva
