Auto-select a value in a custom field based on other custom fields' values
Nur Fatin
I have a team-managed project and I have five custom fields which are all dropdown. Each field will have values for the user to select. For example the custom dropdown fields and values are as of follows:
1. How long is your travel time?
  • 30 minutes
  • 1 hour
  • 2 hours
2. Do you travel by bus?
  • Yes
  • No
3. Do you travel by train?
  • Yes
  • No
4. Which Tier?
  • Tier 1
  • Tier 2
  • Tier 3
Based on the examples above, is it possible to set up an automation rule whereby the last custom field (4. Which Tier?) will auto-select the values (Tier 1, Tier, 2, Tier 3) based of the custom dropdown fields' values selected?
For example, I want 4. Which Tier field to auto-select Tier 1 as its value when the user selected these values for previous fields and so on:
1. How long is your travel time? 30 minutes
2. Do you travel by bus? Yes
3. Do you travel by train? Yes
4. Which Tier? Tier 1 (to auto-select based on 1-3 values selected)
1. How long is your travel time? 1 hour
4. Which Tier? Tier 2 (to auto-select based on 1-3 values selected)
1. How long is your travel time? 2 hours
4. Which Tier? Tier 3 (to auto-select based on 1-3 values selected)
If it is possible, I appreciate a step-by-step guide on how to set up this automation rule.
Thank you.
Andrei Cuzuioc _ScriptRunner_
Hi! This is possible with ScriptRunner's Behaviours feature. Here's a similar example explained in a demo video. This feature is not yet supported on JSM.
Mohanraj Thangamuthu
November 11, 2024
Hello, Good day. Looks like your requirement is specific to the feature request : https://jira.atlassian.com/browse/JSDCLOUD-3457
Nur Fatin
Hello Mohanraj, thank you. May I check if there is another way to do this?
November 12, 2024
Hello, thanks for the update. One option is to use automation like : https://community.atlassian.com/t5/Jira-Service-Management/How-to-set-a-field-value-based-on-other-custom-field-value/qaq-p/1773343
Or you can explore addons like Scriptrunner to achieve this requirement. Thanks
Like Nur Fatin likes this
