×Hello there,
I try to make autoamtion sending messages to MS Teams webhook once test automation is created.
I would like to see test count, number of passed and failed test.
There is a documentation from Xray:
https://docs.getxray.app/display/XRAYCLOUD/Integration+with+Microsoft+Teams
However my messages are still without number regarding tests.
I don't know how to verify what is inside these variables like:
{{webResponse.body.data.getTestExecution.testRuns.results.status.name.match(
".*(PASSED).*"
).size|
0
{'data': {'getTestExecution': {'issueId': '1028525', 'jira': {'key': 'CTB-4977', 'customfield_10033': None}, 'testRuns': {'results': [{'status': {'name': 'PASSED'}, 'test': {'jira': {'key': 'CTB-4847'}}}, {'status': {'name': 'PASSED'}, 'test': {'jira': {'key': 'CTB-4848'}}}, {'status': {'name': 'PASSED'}, 'test': {'jira': {'key': 'CTB-4849'}}}, {'status': {'name': 'PASSED'}, 'test': {'jira': {'key': 'CTB-4873'}}}, {'status': {'name': 'PASSED'}, 'test': {'jira': {'key': 'CTB-4850'}}}, {'status': {'name': 'PASSED'}, 'test': {'jira': {'key': 'CTB-4615'}}}, {'status': {'name': 'PASSED'}, 'test': {'jira': {'key': 'CTB-4972'}}}, {'status': {'name': 'PASSED'}, 'test': {'jira': {'key': 'CTB-4678'}}}]}, 'testEnvironments': [], 'testPlans': {'results': []}}}}
Automation log also confirm all my posts were successful ( so token etc should be correct )
So question is if these variables are up to date in xray documentation?
How can i check what is inside these variables?
Or do you have any other idea how to get information like test count, passed and failed tests?
There is better structured json file:
json_data = '''{
"data": {
"getTestExecution": {
"issueId": "1028525",
"jira": {"key": "CTB-4977", "customfield_10033": None},
"testRuns": {
"results": [
{"status": {"name": "PASSED"}, "test": {"jira": {"key": "CTB-4847"}}},
{"status": {"name": "PASSED"}, "test": {"jira": {"key": "CTB-4848"}}},
{"status": {"name": "PASSED"}, "test": {"jira": {"key": "CTB-4849"}}},
{"status": {"name": "PASSED"}, "test": {"jira": {"key": "CTB-4873"}}},
{"status": {"name": "PASSED"}, "test": {"jira": {"key": "CTB-4850"}}},
{"status": {"name": "PASSED"}, "test": {"jira": {"key": "CTB-4615"}}},
{"status": {"name": "PASSED"}, "test": {"jira": {"key": "CTB-4972"}}},
{"status": {"name": "PASSED"}, "test": {"jira": {"key": "CTB-4678"}}}
"testEnvironments": [],
"testPlans": {"results": []}
Hi @Vojtech Kalab -- Welcome to the Atlassian Community!
In your rule after the REST API call to get the test results from Xray, please try writing this to the audit log:
{{webResponse.body.data.getTestExecution.testRuns.results.status.name}}
That may confirm if the message is (or is not) being interpreted in a manner that can be parsed, or if it is plain text.
Hi Bill,
thank you for the kind welcome.
Thank you for your suggestion. It helped me to find out, my variables are empty, because i didn't check option:
Delay execution of subsequent rule actions until we've received a response for this web request
Thank you very much.
