Automatic Asset Export Using Java API
Zac Boyd
Wanting to know if anyone has got a way to export assets automatically.
Using Data center LTS 9.4.11 and have scriptrunner.
Idea was to get the code working in script console first then change into a "Job"
Error: 2023-11-07 00:49:35,938 ERROR [runner.ScriptBindingsManager]: Export data is null.
Attempted code so far:
import com.onresolve.scriptrunner.runner.customisers.PluginModule
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import com.riadalabs.jira.plugins.insight.channel.external.api.facade.ConfigureFacade
import com.riadalabs.jira.plugins.insight.services.imports.model.schema.ExportObjectSchemaDataBean
import com.riadalabs.jira.plugins.insight.services.progress.result.ProgressResultBase
import org.apache.log4j.Logger
import org.apache.log4j.Level
@WithPlugin('com.riadalabs.jira.plugins.insight') insightPlugin
// Define the export configuration
String fileName = "FileName.zip"; // Specify the file name
Integer objectSchemaId = 1; // Replace with the actual object schema ID
String objectSchemaName = "Model Name"; // Replace with the schema name
boolean includeObjects = true; // Set to true to include objects
// Create an instance of ExportObjectSchemaDataBean
ExportObjectSchemaDataBean exportDataBean = new ExportObjectSchemaDataBean(
fileName,
objectSchemaId,
objectSchemaName,
includeObjects
// Inspect the methods and properties of the ExportObjectSchemaDataBean object
def methods = exportDataBean.getClass().getMethods()
def properties = exportDataBean.properties
if (exportDataBean) {
def output = exportDataBean.getResult();
if (output) {
// The export data is now collected and can be saved to a file or processed further.
def exportFilePath = "/var/atlassian/application-data/shared-home/export/insight/FileName.zip" // Replace with the desired file path
new File(exportFilePath).text = output
} else {
log.error("Export data is null.")
} else {
log.error("ExportObjectSchemaDataBean is null.")
SERVER
