I have configured triggers for auto transition of issue status. To be precise, when a Pull Request is raised in Bitbucket, status has to change from one to another. i.e Coding/Unit-Testing/Integ-Testing ---> Code Review. This happens correctly from Unit-Testing/Integ-Testing statuses, but from Coding--->Code Review it never does.
How to debug using the logs/triggers.. What are the files that I should check?
I would recommend trying to follow the documentation on configuring this in Jira, https://confluence.atlassian.com/adminjiraserver071/configuring-workflow-triggers-802592811.html#Configuringworkflowtriggers-troubleshootingTroubleshooting
specifically there is a section of that doc on Troubleshooting:
Troubleshooting
If you are having problems setting up a trigger or getting a trigger to work, follow the steps below to troubleshoot your problem.
