Automatically Create SubTasks for on demand Jira
Jithin Heric September 16, 2012
Is there a way to automatically create subtasks for a particular issue whenever the issue is created using Ondemand Jira ? For example whenever an Issue is logged it should automatically create a two sub tasks dev and QA.
Thanks in advance,
Jithin
Jobin Kuruvilla [Adaptavist]
September 16, 2012
It requires some customizations and hence not possible in onDemand.
Jithin Heric September 17, 2012
Thanks Jobin but is there a way to prioritise this issue because I am sure there are many more users who would like this change.....
September 17, 2012
You can create a feature request with Atlassian ;)
Harry Chan
September 17, 2012
There is a plugin for this too, but as Jobin has said it can't be installed on OnDemand.
Harry Chan
September 17, 2012
Yeah that's the 1. Unfortunately this is the current situation. If you do need a hosted JIRA and need this now, you might need to go with a separate third party hosted JIRA solution. No other solution yet on OnDemand.
Bob Swift
September 17, 2012
Specifically Create on Transition Plugin for JIRA . This is a topic discussed elsewhere and there are Atlassian efforts to improve the situation for OnDemand. Wait and see at the moment.
Help us plant more trees
