Automatically Set Due Date to Jira Server issue using Script Runner
siva
We are using scrip runner plugin in my jira server instance by using this plugin i need to create scripted  custom field that automatically Set display number of days the issue is due in and this scripted custom field is filled manually while creating a issue and then it automatically Set display number of days left. Please help me with script how to achieve this issue.
Siva.
Nic Brough -Adaptavist-
June 22, 2022
This isn't going to work
Scripted fields are not enterable, they are calculated
Reporting and searching is not going to be reliable, unless you re-index, or at least view, every issue with your scripted field on it every day just after midnight.
siva
June 22, 2022 edited
@Nic Brough -Adaptavist-
Thanks for the reply,
Sorry for i wrote the question wrong way actually Due Date field is system field that is manually entered by user while creation of issue. Here i need new script custom field (Due Date Indicator) that calculates how many days left from  Due Date system field. Please help me on this.
Siva.
June 23, 2022
I don't think you wrote it incorrectly at all.
Your "number of days left" field is not going to work because of what I said in my original answer.
