Automatically assign parent issue custom field to sub-task
Adam G
February 9, 2024 edited
I'm trying to set up an automation where when a sub-task gets created, it automatically inherits the value of a custom field (in our instance, this is "Scrum Team", customfield_10035) from the parent issue.
The code I have in place at the moment is:
"fields": {
"customfield_10035": "{{issue.parent.customfield_10035.id}}"
When the automation runs, I see an error:
Error editing issues
XYZ-20570 (Specify a valid 'id' or 'name' for Scrum Team (customfield_10035))
It looks to be expecting an actual value for the Scrum Team, rather than inheriting it directly from the parent issue.
I want to be able to allow this automation to run right across our project, which has many scrum teams within it, so ideally want to get this value from the parent issue.
I'm not the project owner, although I can ask them to create the automation if needed. I'm also not a Jira admin as our organisation is a large one, so its managed by a completely different team.
Any help is appreciated!
Rik de Valk
Hi @NimbleGrimble ,
I think you can use the Edit Issue action, select the field 'Scrum Team' (in the below example I selected a field 'Backout plan').
Then hit the ... behind Scrum Team and switch it from Set to Copy. And switch the 'Issue to copy the value from' from Current issue to Parent issue.
Adam G
February 12, 2024
This did it! Thank you! The "Set" option didn't have "Copy from parent" like the Assignee value did, so I didn't think that was possible... That worked great! Thanks again!
Like • Rik de Valk likes this
atlassian, team ’25 europe, virtual access, catch team 25 virtually, anytime anywhere, hybrid event, atlassian conference, atlassian learning, ai teamwork, remote attendance, digital access pass, keynote livestream, product announcements, community events
Register for free Team '25 Europe digital access
Get your free all-access digital pass and don’t miss groundbreaking announcements, brand new features and product updates, insight-packed sessions, and exclusive digital content.
Sign up
Upcoming Jira Events
