Automatically create project shortcut for Confluence space
Nick Ugraitzky June 9, 2020 edited
I was working on a listener in Scriptrunner, which automatically creates the Confluence space on the ProjectCreatedEvent and links it between the space and the Jira Project.
This works fine already - now I want to have the URL for the space copied into a project shortcut aswell. I found this topic: https://community.atlassian.com/t5/Jira-Software-questions/How-can-we-create-JIRA-project-shortcuts-via-API/qaq-p/914760 but asked myself if there isn't a JAVA API I can use rather than JS or REST API.
Thanks in advance!
Nick
Okay, found a solution myself with Scriptrunner. I excluded it from the listener and created a fragment/web item. Section is jira.project.sidebar.settings.navigation and link is /confluence/display/${project.key}
Jelena Saveljic April 18, 2021
Hi Nick,
Can you please provide code of a listener in Scriptrunner, which automatically creates the Confluence space on the ProjectCreatedEvent and links it between the space and the Jira Project?
Nick Ugraitzky April 18, 2021
Jelena Saveljic April 19, 2021
Thank you!
SERVER
VERSION
8.6.1
