Automatically create subtasks for multiple people
Maycon de Souza Leal
I would like to know if it is possible to create an automation in a JIRA project where automatically create sub-tasks for each user informing in a custom field of multi-user picker.
And if possible, assign each user to their respective sub-task.
I inform you that I use the Cloud version of JIRA.
I found something similar in this post below, but I didn't understand how to create the automation.
https://community.atlassian.com/t5/Jira-questions/Automatically-create-subtasks-for-multiple-people/qaq-p/1852967
Thanks.
August 25, 2023 edited
Hi @Maycon de Souza Leal
What parts of the other examples / information did you not understand?  And, did you look over the information I provided in the other thread on advanced branches?
To get you started on creating your rule, please refer to these documentation and example sources:
I tried to create the automation with what little information I understood.
Here are some prints below:
However, automation cannot create the sub-task and set the assign.
What can I be doing wrong?
August 25, 2023
Please try to assign the subtask at the same time you create it, in one action.
That can be done by typing in the smart value in the field, it will appear below the field, and then it can be selected:
{{myApprovers}}
Like David Blank likes this
I didn't understand where I should type the smart value.
Within the options of the creation action, I only have these fields:
August 25, 2023
Please try that in the assignee field when creating the subtask.
WORKED PERFECTLY!
Thanks a lot for the help @Bill Sheboy
Like Bill Sheboy likes this
