When I create an Issue I want other five issues to be created linked. This is easy with addons in principle, but I want it to be a link that later on I will be able to see in portfolio and follow.
If I do the configuration in portfolio by hand, I get a link called Child of. This does not appear as a normal link in Jira or anywhere else, so I am not able to use it.
I cannot use normal links in Jira because then in portfolio i cannot open and close them like a hierarchy. I could work it using dependencies but it is not the same, they are child issues of the parent.
Any ideas on how to achieve this? Compatible addons?
Best REgards
If anyone finds this in the future, solution:
Dont use the links, copy the key of the parent in the custom field parent link of the new issue, I did it with JSU. But I guess more addons will be compatible.
