×Hi There
What am I doing worng here?
The objective is to loop through a list of looked-up issues and comment on each of the lookup issues.
For some reason this automation does not loop through the lookup issues, but comments on the trigger issue multiple times.
I am obviously missing something
I tried branching with both smart values and JQL. The JQL option gives and error.
Any assistance will be greatly appreciated
Marius
Hi @van den Bergh, Marius, Vodacom (External)
This appears to be a duplicate of your earlier question, possibly caused by the connectivity issue you noted:
Hi @van den Bergh, Marius, Vodacom (External) - Rather than a Lookup Issues action, I would recommend creating a JQL branch using the query in your Lookup Issues action. It will be more efficient and should deliver the desired results.
