Automation Bug: Edit Field not working
Ryan Willms
My automation is quite simple:
When: field edited
Then: Update same field in sub-tasks
I did it this morning and it did not even trigger. The only thing I can think of is that I see a UI update (eg. "Add people", "Add date") and in classic Atlassian fashion, this has broken easy workflows.
John Funk
Hi Ryan,
Atlassian has an ongoing active incident with its products due to AWS issues. Are you sure the Rule even fired? Also, screenshots are always helpful - the full rule, audit log when it runs, etc.
Ryan Willms
The rule is not being fired. Perhaps this is due to AWS.
John Funk
That's my suspicion. Are other rules firing though? Does this rule get fired as the result of another rule firing? Or is it executed directly? On other words, is the Box field updated sometimes as the result of another automation rule firing? Or is it always just when someone updates it directly on the screen?
Ryan Willms
No automations are firing, and I just posted out of frustration. Seems likely it's the AWS issue - thanks for all inquiries
John Funk
Yep, hopefully that's it and it's back up and running soon. The good thing is that the automation rules tend to fire and catch up when down like that. Hopefully that will be the case.
John Funk
Hey @Ryan Willms  - did this all get cleared up now that things are back to normal?
Ryan Willms
There is no audit log, because the trigger is not even happening, despite matching the conditions.
Gor Greyan
October 20, 2025
Hi @Ryan Willms
Did you editing the "Box" field, or it is being edited via another automation?
October 20, 2025
Hi @Ryan Willms
For a question like this, context is important for the community to help.  Please post the following:
  • what version of Jira are you using: Cloud, Server, or Data Center
  • for Cloud, what type of project is this: company-managed, team-managed, JPD, etc.
  • an image of your complete automation rule in a single image for continuity
  • images of any relevant actions / conditions / branches
  • an image of the audit log details showing the rule execution
  • explain what is not working as expected and why you believe that to be the case
Until we see those...
As you describe it, the rule could not work: without a branch to the subtasks, they could not be accessed for an edit.
And, some field updates do not trigger the Field Value Changed trigger.  The reason is there are separate triggers for them.  For example, assignment, status transition, comment changes, work logging, etc.  Seeing your complete rule will help to confirm this.
Gor Greyan
October 20, 2025
Hi @Ryan Willms
Could you please provide screenshot from the Audit Log of the mentioned automation?
