Automation - Copying a field when changing issue type
Heidi Vanderholm January 20, 2025
I'm trying to create an automation so that when we change an issue from a bug to a different issue type, the "Bug Description" (which is what we use instead of the Description for bugs) automatically transfers into the "Description" field in the new issue type. Or vice versa. Can someone help? I'm stumped..
4 votes
Bharat Kalia
January 20, 2025 edited
Hi @Heidi Vanderholm - Hope you are doing well. If you want you can built something like below -
1. Trigger - When value changes for "Issue type" Screenshot 2025-01-20 at 2.06.13 PM.png
2. Just make sure the issue type is not equal to "BUG" since you are moving out from bug (It's just an extra step)
3. Action - edit issue field for "Description"
Copy BUG Description from current issue. (The screenshots might show Description because I don't have BUG description on my instance)
You can also refetch and clear the BUG description after this step if needed.
Please let me know if this helps.
Bharat
@Bharat Kalia That worked, thank you!!
Like • Bharat Kalia likes this
Trudy Claspill
Hello @Heidi Vanderholm
To help us help you, please provide the following:
1. A screen image that shows your entire rule.
2. Details of any steps where you are trying to set the Description field based on the Bug Description field.
3. The output from the rule execution in the Audit Log.
@Trudy Claspill Hello, thank you for your reply! I did not have an automation yet, but rather was looking for someone to help me get one set up. The other comment explained how to create the automation that I was looking for.
Let's build A Rovo Agent 🤖
Save your spot
