Automation - Create new issue and copy attachment from trigger issue
philipf
May 22, 2024
In jira cloud I have
- Two ticket types (pre-approval, and expense approval)
- They are on the same workflow
- What I would like is for when a pre-approval ticket is approved, it automatically generates a reimbursement ticket. So I used a the trigger 'then create new" to create the new ticket copy fields from trigger issue, and what I am trying now to do is copy the attachment from the trigger issue.
Which is not working since attachments is a required field, and the automation is failing since saying no attachment.
Is this because the ticket is created before the fields are set, and thus no attachment. I am not sure this is it since the other fields whicha re copied from the trigger are not kicking back errors.
Any thoughts on how I can get the workflow to work with adding attachments so doesn't fail.
Kalyan Sattaluri
May 22, 2024
Hello @philipf
Is "Attachment" a required field when creating your "reimbursement ticket"?
If so, that is a problem.
We cannot create Issue and add attachments at the same time.
You have to create the issue first and then using the created issue key, make a send web request call to add the attachment endpoint..
So there is no work around I am aware of.
You can relax the reimbursement ticket requirement, that is, attachment is optional, but handle it in a workflow later, that is, unless there is an attachment, you cannot proceed the issue to next stage etc..
Hope it helps, Thanks.
