×Hi Community,
If I add an issue to an Epic, how can I detect which child issue starts first and copy its Start Date to the Epic's Start Date?
Thank you!
Hi @Amy Chang
What have you done thus are to solve this need?
If you have an automation rule and it is not working as expected, please post an image of your complete rule, the audit log details, and describe what is not working. Those will provide context for the community to offer suggestions.
If you have not started a rule, I recommend trying to do so. This will help you learn more about rules and be better able to confirm the problem solved meets your needs. Your rule could use the Lookup Issues action, with JQL, to gather the child issues of the epic, and then identify the earliest date with the min function, such as with:
{{lookupIssues.Start date.min}}
Before building the rule(s), I recommend confirming your understanding of what to do in several cases as additional rules may be needed. What happens when...
Hi @Bill Sheboy
Thank you for your reply.
I did this by comparing the start date of the trigger issue and the Epic. If the trigger issue's start date is less than the Epic's start date or the Epic's start date field is empty, it will copy the trigger issue value to the Epic.
However, I think the lookup issue action will be more precise. If I use the current method, even the system copies the value from the child issue, but we cannot guarantee that the date is the earliest date from the child issue.
I tried to use Smart Value Comparision to compare the original Epic ({{#changelog. epic link}}{{from}}{{/}}) and the new Epic ({{#changelog. epic link}}{{to}}{{/}}), and lookup the value from the new Epic if a child issue added in it. However, it doesn't work, and it seems the lookup action didn't support the Start date field. So I'm still figuring out how to read the child issues' Start Date when an issue is removed from an Epic.
Are you using Jira Cloud, Server, or Data Center version? If using Jira Cloud, the Lookup Issues action supports all current issue fields, including Start date.
And...the Epic Link field is sunsetting for linking Epics to their child issues in Jira Cloud. Instead please use the parent field.
For the change of epic parent scenario, you could call Lookup Issues twice to update the two impacted epics...
To find the child issues of the current parent:
parent = {{triggerIssue.parent.key}}
To find the child issues of the previous parent, first confirm there was an old parent, and then use this JQL:
parent = {{#changelog.parent}}{{fromString}}{{/}}
