Automation: Epic Transition
Amy Chang
April 29, 2024 edited
Hi Community,
I want to ask some questions related to the Epic transition. Here are the scenarios that I didn't know how to do:
1) When a WIP task is removed from an Epic (A), and the rest of the child issues in Epic A are in Done status, move Epic A to Done.
2) When a WIP task is removed from an Epic (B), and the rest of the child issues in Epic B are in Open status, move Epic B to Selected for Development.
I tried to use {{#changelog.epic link}}{{fromString}} - {{toString}} to record the original parent; however, it doesn't work.
Dexter de Vera
Hi @Amy Chang ,
Try to create automation like this:
Trigger: Field value changed - parent
For: Branch rule / related issues:  JQL ->
IssueType = Epic AND Issuekey = {{fieldChange.fromString}}
      If: Related issues condition: Children - All Condition specified JQL - statusCategory = Done
          Issue fields condition: Status not equal to Done
          Then: Transition issue - Done
Amy Chang
May 1, 2024 edited
Hi @Dexter de Vera ,
It works well.
I also tried to use {{#changelog.epic link}}{{from}}-{{to}}, it works as well.
I have another question about the Epic transition.
Scenario: When I add a child issue that is not in Done to a Done Epic, the Epic automatically moves to In Progress.
However, there are some status combos not suitable for this case:
  • Closed + Open/Priority/Blocked => Selected for Development
  • Done + Closed => Done
Accepted combos:
  • Done/Closed + WIP
  • Done + Open/Priority/Blocked
  • All WIP
I don't know how to set better the condition I want for the status combination.
Register now
