×Hi All
I am looking for a way to popup a warning when editing a custom field.
The field needs to be editable by anyone but should display a warning along the same way as when you pull in a ticket mid-sprint you get a Scope Change warning.
It would be great if you could do this with Automation with the Custom Field Value Change trigger. It would be better if it could be On Focus.
If not Jira could this be done using Script Runner?
Hi David - Welcome to the Atlassian Community!
Unfortunately, Automation cannot popup any screens for the Field Value Change trigger (or any trigger for that matter). You might be able to do it with the ScriptRunner Behaviours app.
