i am trying to have a rule whereby upon creation of a new Epic, and based on particular criteria, it will automatically link an item to a particular "parent link"/Initiative issue type already created.
i can't seem to do this and may need to be done through the advanced section of the rule builder
my knowledge here is limited and i started drafting the below but pretty sure that is wrong.
in this instance i want to add a parentlink to any created item to ID 781
{"update": {
"issuelinks": [
"parentlink": { "id": 781}
First thing, I believe the Parent Link field has been deprecated as Atlassian standardized the relationships between issues to use the Parent field.
Next, your question seems to indicate you are using the Free license of Jira. If that is correct, I believe you will not be able to add additional levels to the issue hierarchy as that is only supported for the Premium and Enterprise license levels. And so even if you link the issues by Parent, that will not impact the features like reports and roadmaps for the Free license.
thanks Bill
Parent field is fine to use, whatever can be used.....but cannot seem to find a way.
when I select Parent as a field to modify in the rule builder, I do not seem to be able to set an ID to it.
I am using an enterprise account to test my scenario
the options are to link as a parent to the current issue or trigger issue. instead i wish to set it to a defined Initiative
based on that I then proceeded to use the additional area of the rule builder to specifically define this, but i am not sure that is possible?
If you are trying to set that to a specific key in a rule, I believe you will need to first save the key in a Created Variable, and then reference that.
For example:
When you type in the smart value, it will appear below the field. Select it to use it for the edit.
Fantastic!!! that works.
thankyou for the help
Hello, I'm trying something similar -- want to update Parent of a story with an epic key. The rule runs successfully but it does not update the parent field. What did I do wrong?
Hi @Cheri Kure -- Welcome to the Atlassian Community!
Would you please post images of the audit log details showing the rule execution and of the Create Variable action? Those may help explain what you are observing. Thanks!
What are the types of issues involved? Specifically, is the trigger issue a Story and the "parent" issue an Epic?
What is the type of project: company-managed or team-managed?
What is in the Create Variable action:
The Jira issue key is valid and is in the same company-managed project.
The Create variable action simply has the variable name I created of varMyParentKey and the Jira issue key of the Epic issue.
In the Edit issue fields action I've selected the "Parent (textfield)" field and entered {{varMyParentKey}}. If I use the "Parent (System)" field I cannot enter my variable as it only allows a selection of either Current issue or Trigger issue.
It appears someone has created another Parent field, which will definitely cause problems. Please discuss this with your Jira Site Admin to learn why it was added because there should only be one.
To use the system field in the edit, the dropdown makes it appear no value can be smart value entered. You may type in your smart value, and it will appear below the field. When it does, select it for use.
Thanks so much Bill, I'm not used to being able to paste data into a dropdown list field. That worked perfectly.
Bill Sheboy - thanks so much for you info here - totally worked for me! The last trick was entering the smart value in the Parent field where is only has two choices and then selecting it. Sensitive JIRA.
Thanks jod! That last trick of selecting the smart value you pasted in was causing me nightmares until I saw your post. Overly-Sensitive Jira!
The workaround with smartvalues is:
Replace the customfield id with the ID of your Parent Link customfield and set the issue you prefer.
{ "update" : { "customfield_15005" : [{"set" : "{{triggerIssue}}"}] } }
