Automation Rule Throttled - Exceeded Processing Time Limit
Diego Martínez February 4, 2025
Hi everyone,
I'm experiencing an issue with an automation rule in Jira Data Center where it gets throttled due to exceeding the allowed processing time limit. The error message states:
"Automation for Jira has exceeded the allowed total processing time for this rule. Maximum allowed processing time over 12 hours is (in seconds): 3600."
Has anyone encountered a similar issue? Any suggestions on how to optimize this rule to prevent it from being throttled?
February 4, 2025
Hi @Diego Martínez
If you look at the top of the rule in its details, did you enable the "Allow Rule Trigger" option?
https://confluence.atlassian.com/automation/create-and-edit-jira-automation-rules-1141480599.html
If so, your rule is recursively triggering itself whenever a time tracking field changes, and so likely using up your limits for both "loop detection" and processing time: https://confluence.atlassian.com/automation074/service-limits-1141481147.html
The "Allow Rule Trigger" option should be used cautiously and only when absolutely needed.  Otherwise it could create many types of rule errors and update collisions.
Next, your rule is making three edits to the same issue.  That could be done with one single edit to cut the processing time by approximately two-thirds.
Diego Martínez February 7, 2025
Thank you very much Bill! That’s exactly what I did. I combined the edits into a single action to make the rule more efficient. 😊
Like Bill Sheboy likes this
Learn more
