How to set automation rule in JIRA to run specific name of transiton by schedule?
For example:
The transition A need to run daily on 6PM.
You have to trigger a scheduled automation that runs daily at 6pm with the given scope of issues and transitions the tickets to the given status?
When you say explicitly a 'transition name' , are you facing issues due to multiple transtions to the statuses? If so, the regex can help
Thank you for the feedback @Fazila Ashraf .
Yes, I have many status in JIRA, but I need to run the specific transition that currently being looping transition. And this manually can works on any statuses.
Cool.. Then i recommend you to try the combination of the 'Destination status' with the 'Transition match' regex.
Register now
