Automation - Web Request - How to Handle 404 Errors
Calvin
July 9, 2024
Hi all, I have a web request to a link in an automation, the link sometimes gives 404 errors when its down.
The thing is, this completely errors out the Web-request automation. Is there any way to handle these requests, as I'd rather just add a comment to the ticket about the error as opposed to the automation itself failing and emailing the Automation Owner.
5 votes
Jehan Bhathena
July 9, 2024
Hi @Calvin ,
Yes, in order to view the web request's status, you need to check the option "Continue running the rule even if the request response is not successful (i.e. non-200 response)"
You can reference this using the smart value highlighted in the image below:
Calvin
July 9, 2024
Hi Jehan! Thanks so much for the above!
I think I misunderstood the checkbox. I thought it meant "continue running rule" as in continue the web request over and over until a 200. Not that it meant continue the rule as in the whole entire automation!
Calvin
July 9, 2024
Tested now and it works perfect, your a legend, thanks!
Shadab
October 29, 2024
Is this option "Continue running the rule even if the request response is not successful" - is this available only on particular versions of Jira ?
We use Jira 9.4 .. but I do not see this option in the SendWeb Request action.
Thanks.
Jehan Bhathena
October 29, 2024
Hi @Shadab
that option is visible only after the first check box is checked of "Delay execution...."
Let me know if the option isn't available even after you've checked that
Edwin Stol
Hi @Shadab - This option is not available on the Server/DC-version of Jira, sadly.
Like Yves Ettounsi likes this
Shadab
October 29, 2024
@Jehan Bhathena I did check the delay execution checkbox.
Its still not available.
Am I doing something wrong here .. ??
Jehan Bhathena
October 29, 2024
Hi @Shadab
I'd suggest raising a mew question on the forum with the jira_dc tag, you'll get better visibility for this question that way, please add the image in your new question too.
