Dear All,
How can I create this automation process?
Automation:
When a ticket (Bug, Story or Task as issue type) AND "BUILD" as Budget is changed to "Code Reviewed" Status,
a Test issue type ticket should be created (only once), with the following parameters
Summary: same as original ticket
Sprint: same as original ticket
Reporter Group: same as original ticket
Client: same as original ticket
Reporter: same as original ticket
Topic: "QA_Manual"
Status: New
AND the new Test ticket should be linked to the original: >> new Test ticket "tests" the original ticket
Thank you for the help,
Krisztina
Hi Krisztina,
This should be doable. Can you share some screenshots of any automation rule you've been trying to setup? We can then work from there!
Adding to the suggestions from @Hans Polder _Devoteam_ ...
If you have not yet started your rule, I recommend trying to do so. This will help you learn and better ensure the rule meets your needs.
To get you started on creating your rule, please refer to these documentation and example sources:
