Automation - date format error when using logged date to populate custom field
Chris Vernon October 19, 2025
I want to prevent users from editing a field (Customer desired Go Live) on standard issues under an epic. To do that, I'm using the log audit to capture the change and then setting the field back to the prior value.
I am consistently getting this date format mismatch error. I've tried a number of variations to the fieldChange including
  • {{fieldChange.fromString.toDate.format("yyyy-MM-dd")}}
  • {{fieldChange.fromString.toDate("yyyy-MM-dd")}}
  • {{fieldChange.from.toDate("yyyy-MM-dd")}}
but they are all failing - sometimes because nothing is written to the audit and, in the case of {{fieldChange.fromString.toDate.format("yyyy-MM-dd")}} the date isn't getting transformed.
I've tried reviewing a number of posts and the Atlassian documentation without success. Thanks for your help.
5 votes
Gor Greyan
October 19, 2025
Hi @Chris Vernon
There is no need to format the field.
Use the following smart value, which already returns the raw ISO date (yyyy-MM-dd) that Jira expects.
{{fieldChange.from}}
@Gor Greyan thanks for the quick response. I tried that but it also failed.
Gor Greyan
October 19, 2025
Hey @Chris Vernon
Got it, the log confirms the smart values resolve correctly, so the issue is likely that the automation is editing a related issue rather than the trigger issue.
When you use a “Branch rule / related work items,” the smart value {{fieldChange.from}} may no longer exist in that scope.
Try this one:
{{triggerIssue.fieldChange.from}}
Still no joy @Gor GreyanThat smart field seems to not have resolved - no values in the audit.
Gor Greyan
October 19, 2025
@Chris Vernon
Thanks for the information.
Let's do that by creating a variable.
Befor the branch, put
Create variable:
  • Name: oldGoLive
  • Smart value:
Then, inside the branch, edit the field and set {{var.oldGoLive}}.
That worked @Gor Greyan! I had to drop the var. from the edit action, but otherwise that did the trick.
I appreciate your help!
Like John Funk likes this
Gor Greyan
October 19, 2025
Dear @Chris Vernon
Glad that it works.
Also, please accept the answer :)
Have a good day, Chris!
