I have create a rule which updates a status for an issue (transition to done) and I have another rule which run when an issue is transited to this status (done).
The rule starting with the transition works perfect when a user do manually the transition but this rule does not start when the transition is done by another rule and not by the user.
Can you help me ?
Thanks very much
Hi @Thierry Bouvet ,
please validate if this last checkbox is checked in the Rule details of your second rule (the one that needs to be triggert by the first rule):
- Tessa
