×On Cloud I have an automation to update Parent Target Start & End date according to their children.
The condition is passes but the Edit issue part is fails with this error message:
"Key-57 (The Target end must be of the format "yyyy-MM-dd" (customfield_10023), The Target start must be of the format "yyyy-MM-dd" (customfield_10022))."
Here is my date format settings in Admin
Here is the way the date value is displayed on an issue:
And this is the JSON I have under the Edit Issue block of the automation:
"fields": {
"Target Start": "{{llookupissues.Target Start.min}}",
"Target End": "{{llookupissues.Target End.max}}"}
How can I fix it?
Hi @Yaniv
First, there are typographical errors in your smart values for {{lookupIssues}} references. Smart values are name, spacing, and case-sensitive. Incorrect values are returned as null.
Next, that error message tells you the values are in the incorrect format, and must be passed exactly as "yyyy-MM-dd" but passing just the date values sends them in a longer format.
You may use the jiraDate format, as described here: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-date-and-time/#Date-format---
For example, please try this:
"fields": {
"Target start" : "{{lookupIssues.Target start.min.jiraDate}}",
"Target end" : "{{lookupIssues.Target end.max.jiraDate}}"
Thanks @Bill Sheboy . I made the changes and added the "jiraDate" but still having same error. Even when I tried the option of format("<pattern>") it doesn't work.
"fields": {
"Target start" : "{{lookupIssues.Target start.min.format("yyyy-MM-dd")}}",
"Target end" : "{{lookupIssues.Target end.max.format("yyyy-MM-dd")}}"
OK after some diggings I noticed one of your answers in another post where the solution was to force the type of the field using toDate .
Here is my final code:
"fields": {
"customfield_10022" : "{{lookupIssues.customfield_10022.toDate.min.jiraDate}}",
"customfield_10023" : "{{lookupIssues.customfield_10023.toDate.max.jiraDate}}"
Yes, that seems correct. Some of the "date" fields are text, or appear as text, inside of rules and must be converted first. I believe this applies to the Advanced Roadmap fields, in general.
