Automation for Jira Security Vulnerabilities
Rob Sung
February 4, 2025
Hi I'm trying to build some simple automation to set the priority and due dates based on severity of the vulnerabilities.
It appears that vulnerability values cannot be used in automation.
Even though I see that there are matching issues for the given JQL (vulnerability[severity] = CRITICAL), the IF condition appears to fail.
Audit Log:
Are there known limitation in using vulnerabilities in automation?
Trudy Claspill
February 4, 2025
Hello @Rob Sung
What are the vulnerability values for the issues listed in the Audit Log?
Are you executing a JQL statement in your Trigger?
With your rule structure each issue will be checked against the first condition. If that condition is not met the rule stops processing that issue. It does not continue to checking the issue against the next condition. I believe you need to use a different structure; IF/ELSE
if vuln=crit
-- then edit
Else if vuln=high
-- then edit
Else if vuln=...
With that structure the rule will check the issue against each condition until it finds one that passes or it runs out of conditions.
Rob Sung
February 5, 2025
Thank you @Trudy Claspill
I'm using it JQL and it's working now/
