Automation for Jira Send email with customfield valued link
Urmo Luts November 17, 2021
Hi
Is it possible with Automation for Jira to send out some link what include customfield value?
With ETI we use this kind link:
Replying will take approximately two minutes and you can send your reply <a href= https://www.companyname.ee/support/$!issue.key@$!jetiFieldRenderer.renderCustomField($issue, 'customfield_12509')><b>HERE.<b/></a>
But how i should but this kind thing into Automation for Jira Send email form?
Gaurav
Hello @Urmo Luts
This is possible to send the custom field value using Automation. The Automation rule with the action to send email can be configured to send the value as {{issue.[Custom Field]}}, where the property needs to be replaced by the custom field name.
Please refer to the documentation for usage here.
Kindly share if you need guidance with the AUtomation rule.
Please accept the answer if it helps.
Urmo Luts November 17, 2021 edited
Hi @Gaurav
Good link but now i have how i should but link together.
https://www.companyname.ee/support/{{issue.key}} + @ + {issue.fields.customfield_12509}} into one url?
it should like https://www.companyname.ee/support/issuekey@customfieldvalue
Urmo Luts November 19, 2021
