Automation for Jira Send email with linked issue
Urmo
Hi
I created automation what close in Jira one Service Management ticket and create clone into Jira Software project. Now i like to send to user e-mail with new issue link.
How i should set it up?
Seems to be that this way is not working.
Issue between old and new is linked.
Alex Koxaras -Relational-
Hi @Urmo
Do you use two rules to do that, or you do that in one rule?
Urmo
It is same automation but there is steps.
Try refetching the issue first, AFTER you create the new task. You will find the re-fetch component on the actions section.
Like • 4 people like this
@Urmo did that change yield the results you wanted?
Urmo
@Alex Koxaras -Relational-tnx, it did work. I did know this small option.
Like • Alex Koxaras -Relational- likes this
I'm glad to know that!
