Automation - how to asJsonString quote a section?
Martin Cleaver
August 17, 2022
In some previous steps, I perform a web request to Jira's API. The data I get back is okay.
{{#webhookResponse.body.issues}} | {{key}} | {{fields.summary}} | {{fields.customfield_12930}} | {{/}}
Now I want to provide this to a PUT to update a field:
"fields" : {
"description" : {{#webhookResponse.body.issues}} | {{key}} | {{fields.summary}} | {{fields.customfield_12930}} | {{/}}
 I need to asJSONString quote the {{#webhookResponse.body.issues}}...{{/}} section as wrapping in "" would break if the content includes quotes.
Neither {{#webhookResponse.body.issues.asJsonString}} or {{#webhookResponse.body.issues}}...{{/webhookResponse.body.issues.asJsonString}} works.
So how do I wrap {{#webhookResponse.body.issues}} in asJsonString?
This seems like an easy question... not sure why it's eluding me!
Martin Cleaver
August 17, 2022
To answer my own question, I believe it's possible to do this with list.join("\n").asJsonString
Jira smart values - lists | Cloud automation Cloud | Atlassian Support
I'll update when I get a chance.
bmccoy
August 22, 2022
Hi!
Another option might be to use the Create Variable action.  Use that to build up the description text and then in the payload you can just treat it as a plain string e.g. {{newDescription.jsonEncode}}.
Also not sure if you are using the "Additional fields" on the edit issue action or sending a new web request, but if you are using the edit issue action you can just use the built-in description fields instead and it should handle all of that for you.
Brydie
Martin Cleaver
November 1, 2022
Ah yes, I could just use that. It'd be much simpler.
If only DC was at feature parity for Automation in Cloud.
