Automation - "If: any match"?
Fook Lee May 13, 2020
I'm trying to write some automation rules, and I was wondering if there is a way to do an "If: any match" rather than the "If: all match".  It seems like something that should be pretty straightforward but I can't figure it out!
Petr Papousek
years later, not googling this up for the first time, again surprised this elementary functionality everyone would expect is still missing...
anyway, you can (although it's not elegant) switch the logic:
instead of:
if (a OR b OR c) {do this}
else {do that}
create the rule:
if (NOT a AND NOT b AND NOT c) {do that}
else {do this}
also sometimes it could help to split one more complex rule in two/three more simple ones
Hernan Halabi - Elite IT Consulting Group
Hello @Fook Lee you should try using if/else scenarios to do that. If they aren't a lot, that should be a good option
Fook Lee June 10, 2020
Sorry - I didn't see this.  I'm already using if/else scenarios, but right now I have to duplicate my entire workflows for different scenarios because the if/else scenario only supports "if: all match".
hello @Fook Lee sorry for the delay on the response. What do you mean by If only supports all match? I believe that's the purpose of the else scenario to have the OR scenario. Can you share your automation rule to see if I can better assist you?
Marcel Gromball November 4, 2020
i guess he means something like this:
if a then
else if b or c or d then
else
As you can see the else if in the middle is a any match. But right now Jira only supports all match. The advantage of any match in this case is of course saving a lot of repeating. In Jira as it is you would need to write the same part for the cases b, c and d.
Fook Lee November 4, 2020
Ah, again I didn't get a notification and didn't see this...
Thanks Marcel, that's exactly right.  In one example, I'm basically trying to do:
If (summary starts with SR or IN) then
So my automation rule I have is:
if (summary starts with SR) then
else if (summary starts with IN) then
And I basically have to repeat the steps for both cases.
Register now
