Automation rule: copy parent value from cascading select fields to subtask
Jonathan
for some reason it's not possible to select a cascading select field as I can select any other standard fiel for editiing.
So I have to dive into the advanced options.
How can I adress a parent's customfield? And do i have to take into account the special array type that a cascading select requires?
Stefan Salzl
September 14, 2022
Hi @Jonathan ,
I´m not sure if I can follow your requirements 100% but the following community post seems similar to your question:
https://community.atlassian.com/t5/Jira-Service-Management/smart-value-for-cascading-select-field/qaq-p/1482635
Please let me know if this was helpful. Otherwise could you please describe your use case from a functional perspective? which problem you would like to solve with this rule? and furthermore a screenshot of your automation rule to get a better overview.
Best
Stefan
Jonathan
sure.
I want a specific issuetype of subtask to be updated with field values of a set of fields from the parent ticket. To be more specific:
When the subtask is created:
copy field "Prozessteam" from parent (single select field, no problem there)
copy field "Modul" from parent (cascading select field, not available from the standard field selection, so I have to use advanced settings.)
I got it to work now, here is what my JSON looks like
"fields": {
"customfield_15221": {
"value": "{{triggerIssue.parent.customfield_15221.value}}",
"child": {
"value": "{{triggerIssue.parent.customfield_15221.child.value}}"
this question was also helpful
https://community.atlassian.com/t5/Automation-questions/Copy-two-cascading-field-values-from-Parent-to-Sub-task/qaq-p/1632481#U2134430
Like # people like this
Stefan Salzl
September 14, 2022
AWESOME job 💪 Good to know you got that working and thanks for sharing your solution with the community. This can be very helpful for other users with similar problems.
(side note: as an austrian community leader it´s always a pleasure to read some German terminology ;) )
Best
Stefan
Like Jonathan likes this
Jonathan
yes - I know how frustrating it can be to find a previous question that would match ones own predicament but the possible answer was not properly documented :)
(btw. not only german terminology but also from austria ;) )
Like Stefan Salzl likes this
Stefan Salzl
September 14, 2022
Very much appreciate this mindset. Thanks so much. That´s the community mindset 💪🙌
ooooh.....another austrian enthisiast. very cool. I am based in Vienna and we just started to host community event yesterday. If you´d like to I would be happy to connect on linkedin (link is in my profile) for some atlassian and professional exchange ;)
Best
Stefan
ChristopherChilds
Awesome.
I was hovering around with this had many combinations but neither where quite working.
SERVER
