Automation rule
Paulina Mijal June 28, 2022
Dear all,
If is possible to configure an automation to assigne to issue person how was assigned to the issue two statuses before? Eg. let say I have a User Story with workflow: To Do --> In Progress --> Code Review --> Done OR To Do --> In Progress --> Code Review --> Rework --> In Progress --> Code Review -->Done.. Assignee in this example change when the issue is moved to Code Review (other developer work on it). I want to make an atomation that change the assigne to the developer how was assigned to the issue when it was in "In progress" status when the issue is moved to "rework" status.
4 votes
padraik
June 28, 2022
I would capture the developer's username in a different field during the In Progress step.  That way you could set your reassignment to the user in that field when it is appropriate.
Paulina Mijal August 2, 2022
Could you please clarify what do you mean by "capture the developer's username in a different field during the In Progress step"?
padraik
August 2, 2022
as a post-function of the workflow transition to "In Progress", set the value of "Assignee" to your new custom field called "Developer" or whatever you want.
Then, as a post function of the transition from "Code Review" to "Rework", set the "Assignee" field to the value in the "Developer" field.
