Automation rules - summarize 2 rules in 1
Anette Noll
I have my first use case for automation rules and described my problem with it in the attached document. Two very similar rules which I would like to put in one, but I fail on the last step.
November 5, 2024
Hi @Anette Noll
To combine those assignment rules, please use an if / else block to select the path needed:
  • trigger: issue created
  • action: re-fetch issue (I recommend always adding this after the issue created trigger to prevent timing problems.)
  • if / else condition
    • JQL condition: if matches stuff for the first user
    • action: assign to the first user
  • else / if
    • JQL condition: if matches stuff for the second user
    • action: assign to the second user
  • else
    • ??? What do you want to do if neither condition is met?
