Automation - subtasks duedate based on parent's duedate
Maciej Wojtasiński January 26, 2024
I'm trying to create an automation rule that should create subtasks with duedates based on parent's due date. I've read a documentation and tried using {{issue.parent.duedate}} in duedate field but it doesn't work. Any ideas? I don't want to just copy it from parent using COPY option because next step will be using .plusBusinessDays function.
Rebekka Heilmann _viadee_
Hi @Maciej Wojtasiński
can you provide a screenshot of your rule? Depending on what triggers the rule, the {{issue}} will be something different and might not be your Sub-Task.
Have you tried {{issue.parent.Due Date}} with a space?
It looks like this:
Using Due date with space didn't work
Oh but you were right about context of duedate source. It won't be parent, when issue creates subtasks, just {{issue.duedate}}
