×we have a requirement to create stories in different projects when we create an epic. but it should create only when the predefined custom field or a component filled
For example:
1. when I'm creating Epic in a project "A" with a component "X", it should create stories Story 1, Story 2, and Story 3 in the project" B".
2. if i'm creating epic with a component "Y", it should create stories in the project "C"
if I create an epic without that component "X", "Y" it should not create any stories just the epic.
We have JSU, Script runner plugins, version is 8.8.
any help would be appreciated.
You can create an issue using a post function or a listener. To get started you can take a look at this script here. Hopefully it will give you some ideas.
Ravi
@Ravi Sagar _Sparxsys_ thanks for responding. i want this to happen only when the predefined a custom field value given while creating a epic.
i don't see any condition in the script. how can I modify it?
You will have to write a custom script for that.
I'm not good at scripting. do know where can I get help with this?
What have you tried thus far for your rule? Would you please post an image of it?
If you are just getting started, you could use an issue created trigger, conditions for the issue type of epic and and if/else on component, and then create issue actions to select the project and fields.
Please see here for more information:
Triggers: https://confluence.atlassian.com/automation/triggers-993924804.html
Conditions: https://support.atlassian.com/jira-service-management-cloud/docs/automation-conditions/
Actions: https://confluence.atlassian.com/automation/actions-993924834.html
Examples library: https://www.atlassian.com/software/jira/automation-template-library#/label/all/1453
Best regards,
@Bill Sheboy thanks for responding. I have tried with a post function based on the field "Team" as shown in the screenshot. but it is creating stories by selecting any team. but, i want that to create stories only when the team selected "A"
Sorry, I missed that you were trying to do this with ScriptRunner. @Ravi Sagar _Sparxsys_ has given you advice for using that add-on tool.
I was suggesting the use of the Automation for Jira features, which were the links to documentation I provided. There is a free Lite version if you want to try that add-on.
Best regards,
@Bill Sheboy due to our company policies, I cannot install another add-on even it free. i have to achieve this with existing add-ons only.
