Is anyone else having issues with the sizing and scaling of the windows the fields in the automation setup area? Example in the image below you can see that all the summary fields are super cut off, and are only visible on a very wide window.
Hello Quinn,
Thank you for bringing this to our attention.
We have created a bug (JRACLOUD-83921) to address the issue of the field dimension not adjusting to the format of your screen.
As a temporary solution, you can zoom out a bit on your browser when working on that screen.
Thanks for using our community
