Hello Community.
I have a easy question for You I think :)
I want to set automation rule:
"When all sub-task's are transitioned to "done" status, send email to assignee."
I want to make issue (which is parent), and three sub-task for other assignee's. And I want to set automaticlly send email to assignee of parent issue, when sub-task's are done.
Any idea what kind of trigger I need to use?
Can You help? :)
Thank You Tansu.
It looks great, but I forgot to say, I have 3 issue types of sub-task :)
Because now we have rule when sub-task are same issuetype (simple sub-task).
Or am I wrong?
1- For the first IF condition, your solution is right. But it is better to use "Issue fields condition" instead of "JQL condition".
2- You don't have to change second IF condition. My first screenshot checks any sub-issues.
@Tansu Akdeniz Hello, I have a similar question, however, I'm trying to set up where the linked tasks once closed will leave the parent (main issue) open.
