Average calculated field
Mario Fanck April 4, 2016
Hello together,
What we're trying to do is use a calculated field in parent to display the values of the AVG of sub-tasks's custom field.
For example:
Subtask A provides a value of 1 in a dropdown
Subtask B provides a value of 6 in a dropdown
Subtask C provides a value of 3 in a dropdown
We want A+B+C to sum up and make a average into the Calculated Field on the parent issue.
Result: 3,3
best regards
mario
ScriptRunner 3.0.16
Steven F Behnke
April 4, 2016
What add-on are you using to create custom calculated fields?
