Hello together,
How can I Customize my Backlog Overview?
It looks like the following:
So that for example the Priority arrows are at the beginning and not at the end of an issue.
Thanks for the help
Hello Philipp,
Unfortunately, there's no way out of the box to change the order of the field in the right corner of the Backlog Cards.
The only fields that are configurable are the ones you can add at the Left Corner of the card, as you can see in the screenshot below:
For this space, you can configure which fields you want to display and the order by clicking on the three dots icon > Board Settings > Card Layout > Backlog
Allright, thanks.
But why did it work here?
Hello Philipp,
Is this screenshot from a board on your own Site or have you taken it from anywhere else?
I believe that this is a Server instance of JIRA, where this kind of customization is available. Also, it's possible that the card layout was displayed like this in older versions of JIRA, but I'm not aware of it.
Let us know if you have found out any way to do it on JIRA Cloud.
