Is any way to add column (Field names) to the Backlog view ? at this time I can only see the Stories and the Epics on the far right, but I will like to add more columns like estimation, status of story, even number of task, links, etc. I guess I am looking for something more robust like Agile Central :)
You can go to Board Settings - Card layout and add some fields there.
No, you don't need to create new board. You can configure your existing board:
You use next gen project. Card layout customization is not available for next gen projects: https://confluence.atlassian.com/jirasoftwarecloud/working-with-next-gen-software-projects-945104895.html
