Backlog ranking issues
Sara March 13, 2020
We have the same issue explained in the following article. Backlog ranking throws error that other users might be ranking issues. I understand this could be due to Lexoranking running. There is no clear solution mentioned here though
https://confluence.atlassian.com/jirakb/jira-software-throws-ui-error-when-ranking-issues-on-boards-913477224.html
1. How can I edit the Lexo ranking schedule to run after working hours so then it doesnt disrupt users?
2. What else is a solid solution to this issue?
I am on single node server installation and all the parameters as false under Balancing session. Can I just run Integrity check to know the issue? Does this affect performance? Please help!
SERVER
